Reply To: Surface subdivision unexpected behavior
Forum Archive Surface subdivision unexpected behavior Reply To: Surface subdivision unexpected behavior
#25661
dirge0matic
    so what I think you need to do is while in edit mode go into the left panel by pressing N then go to shading/UVs. then select all of your model/faces and hit the smooth button under faces.
    this smooths the model out and gets rid of the angles made by the faces.
