Reply To: submissions
Forum Archive submissions Reply To: submissions
#96408
Wayne Dixon
    HI Molly,
    The way our current system works is a little bit limited.  These exercises have been set to accept video links  (YouTube or Vimeo only I believe) and so they only accept video links.
    You can insert links in the submission text, but I’m not sure if you can create a submission w/o a valid link.
    If you can make it work though, I will see the submissions in the list.
    A video is fine for me, although if you could avoid Google Drive if possible that would be less steps for me.
    (otherwise my Drive fills up with bouncing balls and I have to ‘remove’ them)
    But if you submit your work, and I can see it – I will check it.
    That’s a promise.
