Reply To: Strange issue with Separation
Forum Archive Strange issue with Separation Reply To: Strange issue with Separation
#68547
Matthew Ullrey
    @skeletonball Hidden objects are tricky to find sometimes. 😉 It looks like both objects are selected and can be seen in “Local” mode, normally this will exclude other objects from the view. Often, if you wish to see both objects while in Edit Mode, Shift select both the truck bed and the wheel wells in Object Mode and then switch to Edit Mode. This will ensure that both will be visible and you can make changes to both meshes. It is strange for one of the selected objects to disappear once in Edit Mode unless it is hidden only in Edit mode. I can see its origin point showing so…
    • if you would, try ALT+H in Edit mode; this will unhide any invisible mesh objects if that is the case.
    • You could also just have the separated object selected in the outliner and test to see what it does in Edit mode.
    It is an interesting situation. I do hope these suggestions help.
