Reply To: Strange bevel behaviour
Forum Archive Strange bevel behaviour Reply To: Strange bevel behaviour
#92267
    Hi Bernd @bguenthe ,
    No, it’s not a bug!
    It’s a classic beginner mistake; your model, most likely has so-called ‘double Vertices’.  You probably Extruded or Inset the top Face and then Cancelled the Move part.
    The solution is to Select everything and the Merge the Vertices: press A and then M > Merge > By Distance.
    If that doesn’t help, with everything still Selected,  press SHIFT+N, to re-calculate the Normals.
    But my money is on the double Verts.
