Reply To: Stabilize stroke is disappeared
Forum Archive Stabilize stroke is disappeared Reply To: Stabilize stroke is disappeared
#69417
Adrian Bellworthy
    Hi @jeewon , changing the stroke method will give different options , the stabilize option is available with the spacing, dots and airbrush stroke methods selected. Spacing is the default. If you want a line but want to keep the stabilize option slow down the speed you move the brush, or try change the spacing value slider.
