Reply To: Sphere Collider on Enemy doesn’t change
Forum Archive Sphere Collider on Enemy doesn’t change Reply To: Sphere Collider on Enemy doesn’t change
#28168
Jonathan Gonzalez
    If you take a look at the detection scene when you hit play, it’s throwing an error because the GameManager has not been created in that scene yet. At the top of the Start method it’s looking for that object, and since it can’t find it, everything below that line will not be called properly. The changing of the collider size is set at the bottom of that method.
    You can comment out the GameManager stuff if you do not have that created yet. You could also move that line to the bottom of the Start method below everything else and you should see the sphere collider does change in size after that change. It’s included in the script since it’s part of the next lesson. I can’t save versions of the same script in the project files, so you’ll see completed scripts in some lessons.
    If you take a look at the Exercise_Completed scene you’ll see what the end result should look like with everything working properly.
