Martin Bergwerf is right. If you apply scale it will change the Radius of your control points. This will end up scaling up the object(Rubber). You can correct this by tabbing into edit mode, select all control points, on n-panel->Item tab->change mean radius to 1. This should work as long as you haven’t gone in and changed any of the points radius.
