Reply To: So, I'm not sure if you've run into something like this before, but for whatever reason, once I duplicate and join my stac…
Forum Archive So, I'm not sure if you've run into something like this before, but for whatever reason, once I duplicate and join my stac… Reply To: So, I'm not sure if you've run into something like this before, but for whatever reason, once I duplicate and join my stac…
#25055
thecaitasaurus
    Ok, sooo…It seems the problem is still there. Somehow my UVs are showing up on 2 separate “layers”, so that the second-from-the-top rock has a separate image applied to it from the others. Getting out of “UV Local View” makes it so I can visually consolidate all my UV maps into one space, but I will need to apply 2 images (one for the 2nd rock, one for the rest) in order to texture the stack of rocks. I am very confused! any advice would be appreciated 😛
