Forum Archive › So, as I use the inflate brush, I notice more faces are being made as you smooth it out, however, when I try to inflate th… › Reply To: So, as I use the inflate brush, I notice more faces are being made as you smooth it out, however, when I try to inflate th…
I’ve discovered the problem. I had enable Dynotop but then, accidentally turned it off again using Undo without realising.
