Reply To: Snapping using edge / closest not aligning to edge of object I’m moving. . .
Forum Archive Snapping using edge / closest not aligning to edge of object I’m moving. . . Reply To: Snapping using edge / closest not aligning to edge of object I’m moving. . .
#26571
Jonathan Lampel
    Hmm, that is a bit weird. Could you do it in edit mode instead? I’ve found snapping to be more predictable when it’s working with selected vertices instead of the whole object.
