Reply To: Smoothness not the same as on video/Annotation
Forum Archive Smoothness not the same as on video/Annotation Reply To: Smoothness not the same as on video/Annotation
#58784
    If your subdivision level is the same as Kent’s, then it can  be because you are closer to the mesh when making a stroke.
    With you brush size measured in pixels, when your mesh is far away, then 50 pixels is a largerarea (of the subdivided Cube) than when you are zoomed in on your mesh. And a larger area has more vertices that can be moved around by the brush, therefore giving a smoother result.
