Reply To: Smoothing the keyhole part shows visible triangular seams
Forum Archive Smoothing the keyhole part shows visible triangular seams Reply To: Smoothing the keyhole part shows visible triangular seams
#62596
veltarn
    Oh, well… problem solved… 🙂
    I activated it but brainlessely set it to 180 and  I just figured it out, by reading your answer, that if I set it higher than 60° I start to see seams.
    30 or 40° seems to be the good values, thanks you!
