Reply To: Slight problem with adding a bevel to some parts of the shell (edges)
Forum Archive Slight problem with adding a bevel to some parts of the shell (edges) Reply To: Slight problem with adding a bevel to some parts of the shell (edges)
#72234
Sébastien Lenaerts
    It’s hard to tell from your screenshot, but what if you would isolate your edge you want to bevel with an edge loop (the edge loop is then used to connect your diagonal edges.  Does that change anything?
