Reply To: Slider-cube only works depending on where you move it or by luck/chance. Inconsistent results.
Forum Archive Slider-cube only works depending on where you move it or by luck/chance. Inconsistent results. Reply To: Slider-cube only works depending on where you move it or by luck/chance. Inconsistent results.
#94727
    Hi Kimberly, here is what you have:
    Because the Slider works along the Object’s X-Axis, this doesn’t work correctly.
    Simply Change the Rotation (do not Apply the Rotation!):
