Btw, you also seem to have double vertices. Your middle vertex doesn’t seem to be connected to it’s neighbours. If you run into problems like this, Remove double vertices might help. In other situations, when you get weird shading, shift N to make normals consistent should be one of the first things to try. I hope this is helpful.
