Reply To: Since reading the question and answer below, I tried checking to see if the array has something in it, and if it did, dest…
Forum Archive Since reading the question and answer below, I tried checking to see if the array has something in it, and if it did, dest… Reply To: Since reading the question and answer below, I tried checking to see if the array has something in it, and if it did, dest…
#23083
Jonathan Gonzalez
    Sorry I should’ve been more clear. You can add the destroy line in a few places. Either in the Start function as such:
    void Start ()
    Destroy(gameObject, 5f);
    or after the foreach loop in the explosions function like such:
    void GrenadeExplosion ()
    Vector3 explosionPos = transform.position;
    Collider[] col = Physics.OverlapSphere (explosionPos, radius);
    foreach (Collider obj in col)
    if (obj && obj.attachedRigidbody)
    obj.attachedRigidbody.AddExplosionForce (power, explosionPos, radius, liftPower);
    Destroy (gameObject);
    Note that in this case I just have it instantly destroyed once this function is called. So if I called that function from “OnCollisionEnter” it would then explode and destroy the grenade at the same time to create a more realistic effect. Hope that helps.
