Reply To: Shader Nodes – Unique UV Layouts?
Forum Archive Shader Nodes – Unique UV Layouts? Reply To: Shader Nodes – Unique UV Layouts?
#87767
    Hi @TheRavensCurio ,
    My tag name would be @ Spikeyxxx (without the space, but I check everything anyway, so it’s not necessary to tag me…
    What I mean, is that the Node you have Selected in the Shader Editor doesn’t change the Image used in the UV or Image Editor:
    So, I don’t know what you are doing, but it’s not because of whether you Select the Voronoi, or the Image Texture Node.
