Reply To: seem problem
Forum Archive seem problem Reply To: seem problem
#80168
    I guess he means the seams are still visible, instead of the seams being unnoticeable. That’s a tricky one, specially when you consider how the snapping tool can be finicky at time. Changing the behavior of the snap to active element is very helpful when I run into those cases. You make a vertex the active element that is close to where you want your mesh to snap to.
