Reply To: Security popup on opening the file
Forum Archive Security popup on opening the file Reply To: Security popup on opening the file
#89354
Dwayne Savage
    Goto text editor, click dropdown and select the script, Then click the play button(Run script) on the header. You can also close and reopen blender. when you load the blend file blender will ask again. Note: You can also go to preferences->Load & Save->Then check auto run python scripts. I don’t usually recommend this if you are getting blend files from unknown or untrusted sources.
