Hi @Tachy ,
unfortunately, that is quite a mess…You can start over (recommended!! Just the part with the speakers or everything), or Scale each Edge individually in Y to zero (S, Y, 0).
From Right or Left Orthographic view, use X-ray View and for instance Box Select (or Circle Select) to select through the Model and make sure, that you change your Transform Pivot Point to Active Element:
