Reply To: screen animation problem
Forum Archive screen animation problem Reply To: screen animation problem
#100913
Dwayne Savage
    That usually means you have flipped faces in the UV map. In the UV editor you can select he faces(Face mode selection is 3 on the top row unless you are using emulate numpad option), and press ctrl+m for mirroring. Then press X to mirror on the X axis(Left/right. Y is up/down) and enter or left click to accept.
