Reply To: Scaling, moving, rotating along axis hotkeys not working
Forum Archive Scaling, moving, rotating along axis hotkeys not working Reply To: Scaling, moving, rotating along axis hotkeys not working
#53094
    Curiouser and curiouser…
    Try File > Defaults > Load Factory Settings.
    Something similar happens when you use Industry Standard Keymap, but then W, E, R switches between the Active Tools Move , Rotate and Scale…
    Could it be an Addon that you are using?
    If G switches to the Move Tool, then it is clear that X then deletes…
