Reply To: Rotating GameObjects OnMouseDrag
Forum Archive Rotating GameObjects OnMouseDrag Reply To: Rotating GameObjects OnMouseDrag
#42860
Jonathan Gonzalez
    I have a few lessons here and there covering some rotation using mouse input like this one: https://cgcookie.com/lesson/rotating-turret
    This is a code snippet I’m using in a current project for rotating a tank’s turret:
        void BaseRotation ()
            moveX += Input.GetAxis("Mouse X") * speed;
            baseRotation = Quaternion.Euler(0, moveX, 0);
            turretBase.rotation = Quaternion.Lerp(turretBase.rotation, baseRotation, smooth);
    This just works off the Horizonal axis of the mouse, but you could also add in the Y axis as well. So something like this:
            moveY += Input.GetAxis("Mouse Y") * speed;
            baseRotation = Quaternion.Euler(moveY, moveX, 0);
    So in that code snippet you’re moving both along the X and Y axis. The horizontal axis (Mouse X) rotates the object along the Y axis (like turning your head) while the Vertical Axis (Mouse Y) rotates the object along its X axis (looking up and down). Speed and Smooth are float values that just help it move faster/slower. Hope that helps.
