Reply To: Rotate and Scale doesn't seem to work. I can press the buttons but the object doesn't move for rotate or scale. What am I…
Forum Archive Rotate and Scale doesn't seem to work. I can press the buttons but the object doesn't move for rotate or scale. What am I… Reply To: Rotate and Scale doesn't seem to work. I can press the buttons but the object doesn't move for rotate or scale. What am I…
#22034
Stanley Leland
    You don’t give much information to go on. When you select the object do the edges highlight in yellow? Have you tried selecting it through the object>transform>rotate menu? If you are using hot keys is the curser in the 3d viewport when you press the key? Pretty much just a shot in the dark here. 😉
