Reply To: Rigging an Extendable Robot Arm?
Forum Archive Rigging an Extendable Robot Arm? Reply To: Rigging an Extendable Robot Arm?
#38357
polygondust
    @hadiczech Wow, thank you, that works great! Thanks for taking the time to make that.
    How did you get it to spawn more sections as you pull it out? Is in not modeled at all, but instead generated by the bezier?
    This model is planned for animation, so the only issue is how as you pull, each new section rigidly springs into place, causing the hand to clip back and forth noticeably, so the animation would not be smooth. I’ll look into maybe tweaking this solution to fix that issue. Thanks again for the help!
