Reply To: Resolution/aspect ratio
Forum Archive Resolution/aspect ratio Reply To: Resolution/aspect ratio
#25394
    @stephensamuels I think I know what you mean in that when adjusting both X and Y values, only the vertical axis of the frame changes visually. As far as I know, that’s just how Blender solves the adjustment visually. You simply need to set your desired x and y values and then adjust your camera’s position to frame your shot the way you want. Don’t count on the x and y value adjustment to maintain the desired framing automatically.
