Reply To: Render Texture Problem
Forum Archive Render Texture Problem Reply To: Render Texture Problem
#68364
tobles
    Hi,
    yesn’t.
    I tried to follow the tutorial with eevee, but at the end Kent is baking the texture. I haven’t found the bake option for eevee so I switched over to cycles to fix this, but that didn’t put me forward in cycles.
    If you know the solution for this in eevee I’d be happy if you help me continue this.
    (In case the screenshot doesn’t give the needed information, these nodes are made in “Shader Editor”)
    Greetings,
    tobles
