Reply To: Render output is brighter that the viewport in compositor window.
Forum Archive Render output is brighter that the viewport in compositor window. Reply To: Render output is brighter that the viewport in compositor window.
#76379
Marc Albrecht
    Even though there is no response from the thread opener, maybe this is of help to others:
    Aside from the helpful hint about the compositor, I just spent way too many hours of my life figuring out that Blender in general does not play nicely with industry-standard color management. So the thread opener might want to check if they have installed OCIO or are using ICC profiles. If so, ONLY exr output will work reliably, everything else in Blender is basically broken. For a pipeline project I am currently working on I had to make sure that Blender was started without any system-wide color management active, there was zero way of getting CORRECT colors otherwise (close and almost-good, but not correct).
    (for safety measures: you CAN use external color management with Blender! Just don’t expect it to work the same – reliable – way it does in Nuke, Houdini, Maya, Clarice, Arnold, Renderman, Redshift or pick-your-pet. It’s too much work to get it “close enough”, just use Blender in linear space as far as possible or render to exr exclusively.)
    Marc Albrecht
    — disclaimer: This forum does not inform me about responses. If you want to get a reply to a reply to a reply I wrote, contact me directly please.
