Reply To: reintroducing detail after remesh
Forum Archive reintroducing detail after remesh Reply To: reintroducing detail after remesh
#79162
    Looks like you have Dynamic Topology off, at least in the screenshot. Make sure it’s on. After that the usual suspects are using a low detail size in the subdivide edges and making sure your geometry underneath it’s ok. If not remember the trick Kent uses of using the inflate brush at a low power just to generate geometry and then smoothing.
