Reply To: Question regarding “Copying UV”
Forum Archive Question regarding “Copying UV” Reply To: Question regarding “Copying UV”
#90027
    Now you are probably wondering how that happened…
    It depends on how you made the Objects. If you for instance use a Mirror Modifier on a Cube, Apply it and then Separate By Loose Parts, you might already have changed the Topology:
