Reply To: Question about using JPGs?
Forum Archive Question about using JPGs? Reply To: Question about using JPGs?
#95272
Dwayne Savage
    To answer your question, yes you can use jpeg. Texture artist avoid them, because every time you edit it you lose data. Also they don’t have an alpha channel. As for materialist and shader artist they use them all the time. In the world of 3D, no one cares what format you use. They only care if the end result looks good… or bad if that’s what is needed for the project 😀
