Reply To: Question about the Clip Art shader. Is it possible to us different colors for the base or lines? Or does it only work with…
Forum Archive Question about the Clip Art shader. Is it possible to us different colors for the base or lines? Or does it only work with… Reply To: Question about the Clip Art shader. Is it possible to us different colors for the base or lines? Or does it only work with…
#24448
    You can absolutely use any colors you want to replace black and white. Just plug the white and black into a color Mix node and change the color swatches as desired.
