Well, when you want to make adjustments and changes after things all are set up, normally things will break and you’re going to have a bad time reworking stuffs. It’s just the way it goes. Good thing is, after this has happened to you a couple of times, when you start to work on something, you will begin to work in a way that you know if in the future you need to make changes, you will have less of a headache. So don’t worry, make a save as of your file, break things in it as you try to set them right again. Going through the hassle is going to give you lots of experience points.
