Ok , 2 things off the bat:
- You need to use the object coordinates of the Texture Coordinate Node,
- When you SHIFT + CTRL + CLICK on the gradient node with node wrangler you get a viewer node to see the result of the gradient texture, but the viewer node is plugged into the surface of the material output, we are are working with volume here, not surface, so that is not as useful in this situation. You can use it but you will have to manually unplug the Principled Volume and move the viewer to the volume input of the material output node.
