Reply To: Problems with subsurface and intersecting geometry, finding it hard to completely eliminate pinching and distortions, seeking a better workflow or order of operations
Forum Archive Problems with subsurface and intersecting geometry, finding it hard to completely eliminate pinching and distortions, seeking a better workflow or order of operations Reply To: Problems with subsurface and intersecting geometry, finding it hard to completely eliminate pinching and distortions, seeking a better workflow or order of operations
#56139
spalermini
    This seems like a place for using the Boolean Modifier. You can use one shape to either cut or join with the other. So, you could use the barrel section to cut out the turret section to exactly the overlapping shape. The below example uses Difference. The modifier is on the body that I’m keeping, and use the cubes as the Boolean object. It should play nice with the subsurface modifier as well.
