Reply To: Problem with normals
Forum Archive Problem with normals Reply To: Problem with normals
#99863
    Hi Timor,
    Lowering the Angle of the Smooth By Angle Modifier should also help.
    The cause  is, the inlay around the buttons isn’t deep enough, so you could also lower those Edge Loops.
    You can also, in Edit Mode Select the top Faces, that aer having the shading artefacts, and the CTRL+F > Shade Flat.
