The fact that the Loop Cut stops, gives you the exact part of the Mesh, where you need to look.
If you, for instance Select that area (in Wireframe Mode!) with Box-, Lasso- or Circle Select, you can Hide the rest of the Mesh with SHIFT+H. That helps a lot with the confusion.
