Reply To: Problem with curved corners after applying bevel
Forum Archive Problem with curved corners after applying bevel Reply To: Problem with curved corners after applying bevel
#79093
    It’s just that you had double vertices there. You can just select everything and M to merge by distance and it’ll all be fixed.
    You can usually tell you have double vertices if when you select a vert, the edge next to it doesn’t get highlighted in selection orange color:
