Forum Archive › Problem with curved corners after applying bevel › Reply To: Problem with curved corners after applying bevel
You can also select two Vertices that are on top of eachother, by switching to Wireframe Mode (Z > Wireframe) and box select (or circle select, or lasso select) or you can select everything with A (be careful that you don’t Merge too much this way).
