Are you leaves disappearing when you load the preset? If so, I ran into this issue in the second lesson of the coures: https://cgcookie.com/lesson/modeling-tree-variations?wtime=33
The “Limit Import” option disables some settings from the preset load to optimize viewport performance. If your preset has a ton of leaves, for example, this option will ignore the leaves so your viewport doesn’t slow way down.
