@yukinoh1989 Also looked at your obstace drop.
It’s a good start Yukino, just some little things to adress before moving on to rotations 🙂
– the first platform, the ball is going pretty slow there, you’ve got even spacing instead of speeding up. Then when it falls of the platorm it does speed up suddenly, which looks a bit ‘off’.
First make it speed up on the first platform. Real tight spacing at the top, getting a bit bigger each frame when it picks up speed rolling down the platform.
When it falls of the first platform continue this speeding up in the same way. Also make it land higher on the platform a bit. When it has a lot of speed / momemten, gravity will have a effect of course but it won’t pull it down that much
– the first bounce on the platform can be a bit bigger (because it hits harder when you give it some speed)
– same even spacing on second platform rolling down & second fall towards the ground (the distance it falls away from the platform is pretty good)
– you have even spacing in the bounces on the ground, try to make them nice parabolas
You can do this, just rest those eyes and polish away! it always takes multiple passes to get right ^^
