Reply To: Origin of a wind blown object does not move with its geometry
Forum Archive Origin of a wind blown object does not move with its geometry Reply To: Origin of a wind blown object does not move with its geometry
#67151
    @jimcoote  I was thinking about your ‘problem’ when I was taking a walk outside and you might not know this (I learned this after about 6 years of using Blender..):
    At frame 1, with your Cloth Object selected: SHIFT+S > Cursor to Selected.
    Add an Empty. SHIFT + Select the Cloth Object.
    Now is a good time to disable Lock Object Modes (which is only there to not confuse Blender babys, but you are an adult now!):
    Switch to Edit Mode and select 1 or three Vertices of your Cloth Object:
    Then press CTRL+P > Vertex Parent.
    Play the Animation/ Simulation:
