Reply To: Not sure what I am doing wrong but when I add the empty its attached to my top layer surface. So when I rotate it the planet surface rotates as well.
Forum Archive Not sure what I am doing wrong but when I add the empty its attached to my top layer surface. So when I rotate it the planet surface rotates as well. Reply To: Not sure what I am doing wrong but when I add the empty its attached to my top layer surface. So when I rotate it the planet surface rotates as well.
#29546
mrijwood
    Didnt work. I closed and opened, deleted surface and rebuilt. Then noticed that when I moved layer two by accident it affected layer three a little. Started to look around at UI options and discovered I had apparently hit “O” by accident and turned on Proportional Editing. All works as expected now. Thanks for your help.
