Reply To: Normals
Forum Archive Normals Reply To: Normals
#89572
    With ALT + N you will get the Normal’s menu and you can choose “Flip” for the Normals to get flipped. Keep in mind if there are Normals pointing the right way, with the Flip command it’ll flip that Normals in the opposite direction as well. So you can also use the shortcut Shift + N to recalculate the Normals and Blender will just intelligently fix them for you.
