Reply To: Normal Map tool options in 2.8+
Forum Archive Normal Map tool options in 2.8+ Reply To: Normal Map tool options in 2.8+
#59223
Jonathan Lampel
    Hey William, which uv/shading tools are you referring to? I don’t believe they’ve moved, though you’ll now need to use the UV Editor instead of the Image Editor and the Shader Editor instead of the Node Editor.
