Reply To: Normal map doesn’t show changes in normals.
Forum Archive Normal map doesn’t show changes in normals. Reply To: Normal map doesn’t show changes in normals.
#26906
    Odd, I can’t get the bake to work either. Really stumps me 🤔
    Alternatively, you can bake normals with Cycles. Just hop over to Cycles, add a material to the bake target, add an image texture node, select your bake texture, leave the image texture node selected, and bake your normal map (bake menu in the same spot as blender render.
