If the shading appears like that on the normal map, is it always incorrect or is that acceptable shading if the 3d model looks good?
Oh, just saw your example. I would say that the 3D model should be your north star – if that looks good then it doesn’t really matter what technique you use! In this case I would have to check out the model itself to see why the left side was giving the wrong result.
