Reply To: no result on displacement map
Forum Archive no result on displacement map Reply To: no result on displacement map
#77129
Norb Fry
    Hi thanks for the response, Im using 3.4 and I get no warning signs whatsoever, I have been successfully baking normal maps before but this is my first attempt at displacement. I will try again with your trick but I don’t think it will work since no warning sign pops up, if that’s the case I shall instal 3.3 an try again I guess? Thank you
