Reply To: no result on displacement map
Forum Archive no result on displacement map Reply To: no result on displacement map
#77151
    That’s not a bad idea, you could Append the lo and hi res versions in 2.79…
    however, you can’t Bake Displacement that way (only Bake from Multires has that option) and in fact, if you disable Bake from Multires, the Selected to Active is still available..
