Reply To: No need to set characterWeight = 0 ?
Forum Archive No need to set characterWeight = 0 ? Reply To: No need to set characterWeight = 0 ?
#29622
Jonathan Gonzalez
    Technically yes, if you disable the Animator it’ll also disable the IK. The character weight value is through script though, so if you decided to re-enabled the Animator you’d still be using the default characterWeight you had set prior.
